akido
Jan 03, 2017Apprentice
Netgear 810 update
Netgear 810 unlocked I often check the device touch screen for a chance to get a new update to resolve the many issues I suffer from,but sadly nothing in the air ,wonder how netgear a networking comp...
- Mar 14, 2017
The release is still on track for Mar 20.
Steve
zapadak
Mar 20, 2017Star
Sorry the Model was lost in the former Post:
AC810S (Free Model) + Air Cradle DC112 A Zain Version (FW:V1.0.0.4_1.0.60 - is it planned to Update this Firmware in next Future ?)
stevesw
Mar 21, 2017NETGEAR Expert
Hi,
Netgear has confirmed and identified the root cause of the issue affecting interoperability with the DC112A cradle and which is likely causing the reported problems with other 3rd party routers.
The root cause of the issue is related to a change made to the AC810's USB driver descriptors to resolve some compatibility issues in newer versions of Windows.
Given the cradle and router interoperability issues this change has caused, we have decided to remove the change in the short term and repost a new AC810 firmware package.
The current update package has been removed from the update server and a new package will be posted as quickly as possible.
Longer term, we will look at how best to re-introduce the USB driver change while minimizing impact to the cradle and other routers.
Thanks for your patience as we work to resolve this matter.
Steve
- zapadakMar 21, 2017Star
Hi Steve,
thanks for your fast reply and the positive Answer - hope the updated Firmware reaches quick the download server ;-D
Greets
zapadak
- zapadakMar 22, 2017Star
Hi Steve,
Ac810 Receiver today an new Firmware Update NTG9X40c_11.14.08.19 Date 2017/03/20 and it has no Effect in The Situation... The Air Cradle DC112 ist still Not connected to Internet in The Ethernet Ports...
any further solution?
thanks
zapadak
- TeeJay74Mar 22, 2017Virtuoso
I can confirm AC810-100EUS (NTG9X40C_11.14.08.19) with DC112A-100EUS (V1.0.0.18_1.0.60) work very well together.
Air Cradle DC112 A Zain Version (FW:V1.0.0.4_1.0.60 Version ?
- alpha007Mar 25, 2017Aspirant
yes,
i confirme Ac810 cant connected to Internet with cable.
before & after update it could not connect with cable.
sorry for netgear support team.
- TeeJay74Mar 25, 2017Virtuoso
I have too noticed a problem before and after update what comes to USB3 connectivity between AC810 and PC (windows 7, 10 64-bit) RNDIS driver. It keeps detecting device and connection over and over again,device connected/disconnected beeping sound heard continuously. Because it seems AC810 achieves its best performance when using direct USB3 cable connection, development team should investigate what is behind this problem.
