Gabor88's avatar
Gabor88
NETGEAR AC810-100EUS
Hi All!
I need help ASAP, please help me if you can. I bought AC810-100EUS. I would like to use 2CA  with B1 and B3. Is there any possibility to use this bands together? I cannot find any relevant documentation and the helpdesk also could not help.
Thanks!
  • B1+B3 2CA combo is not supported on AC810-100EUS.
    Steve
  • Have you considered to test it by yourself ? It may be the fastest method to find out..
    • stevesw's avatar
      stevesw
      NETGEAR Expert
      Steve
