Oxygene
Aug 16, 2017Apprentice
Netgear AirCard 810s - display is flickering...
I received my new 810s but display seems of a poor quality... Refresh rate is about 20Hz or so and is flickering especially on white background? Do you have the same or is just me? Simon :)
DarrenM
Aug 18, 2017Sr. NETGEAR Moderator
Hello oxygene
I would contact the place you bought the card or contact support and replace the unit if something is wrong with the display.
http://www.netgear.com/support/contact.aspx
DarrenM
