ChrisC66
Aug 06, 2022Aspirant
Netgear AirCard 815s Disconnected all the time.
Hi, The above device came with the camper van. It was working fine. I bought a new sim (the shop made sure it worked) but the broadband tries to find the network but anyways goes back to Disconnected....
ChrisC66
Hi, The above device came with the camper van. It was working fine. I bought a new sim (the shop made sure it worked) but the broadband tries to find the network but anyways goes back to Disconnected. Network is EE in UK. Tried manuel same thing.
- YekingAug 14, 2022Aspirant
Make sure your apn is well configured and make it a default. That way you can have a stable connection otherwise contact your isp
