Recliner22
Oct 04, 2015Aspirant
NETGEAR AirCard Signal Boosting Cradle with Ethernet - DC113A
I would like to purchase a NETGEAR AirCard Signal Boosting Cradle with Ethernet - DC113A but I can't find a source. Amazon says they are unavailable and doesn't know when or if they will get them. ...
- Oct 06, 2015
Hello Recliner22
Sorry to say but this product is end of life and isn't going to be restocked but i did find that the UK amazon still has some in stock.
DarrenM
DarrenM
Oct 06, 2015Sr. NETGEAR Moderator
Hello Recliner22
DarrenM
- Recliner22Oct 11, 2015Aspirant
DarrenM,
Since the cradle you mentioned is being sold in the UK, does that mean that it will only work on 220VAC or can I get a 110VAC power supply from Netgear?
Thanks,
Preston
PS: Will this cradle work OK in the US? - Recliner22Oct 11, 2015Aspirant
DarrenM, Thanks for the reply and the info. Do you know if Netgear is going to come out with a new cradle for the AC791L Hotspot, or are they disconiuing it also?
Thanks,
Preston
- DarrenMOct 12, 2015Sr. NETGEAR Moderator
Recliner22
yes this should work in the US just fine and I dont have any information about a new cradle for aircards.
DarrenM
