JayFray
Apr 11, 2016Aspirant
NETGEAR AirCard Smart Cradle (DC112A)
Hello, Where can I buy the NETGEAR AirCard Smart Cradle (DC112A) in Europe? Thanks.
DarrenM
Apr 28, 2016Sr. NETGEAR Moderator
Hello trib and JayFray
This is a EOL product but you may still be able to find them on amazon.
DarrenM
Jack_T_Chance
May 07, 2016Guide
DarrenM, what does "EOL" mean? :smileyfrustrated:
I'm curious to know if this model would actually be compatible with my Verizon Wireless Jetpack AC791L, as the DC112A Smart Cradle was released a year earlier, and it was stated to be compatible with "all future Netgear Air Cards."
Looking at the Tech Specs for the DC112A, it does not seem to support all the LTE Bands my Hotspot uses, but I just wanted to make sure.
- TGabrieleJul 06, 2016Tutor
It works well with my AC791L.
- BellflowerBJul 31, 2016Aspirant
How did you get the DC112A to work with the Verizon AC791L? Did you buy the DC112A from Australia?
- TGabrieleJul 31, 2016Tutor
Yes. Worked without any problem out of the box. You'll need to get the right AC adaptor or a plug adaptor since they use a different style power outlet there.
