JayFray
Apr 11, 2016Aspirant
NETGEAR AirCard Smart Cradle (DC112A)
Hello, Where can I buy the NETGEAR AirCard Smart Cradle (DC112A) in Europe? Thanks.
MegsDad
Aug 09, 2016Aspirant
eBay? I just bought one that was used with an MEA carrier. It is working fine out of the box with my US AirCard 781S.
Netgear support in the US said they were NLA this spring.
- voodoo69Oct 16, 2016Aspirant
Netgear smart cradle dc112a -1Z1MES firmware Firmware Version 1.0.0.12
I try to update my smart cradle from Netgar site firmware version 1.0.0.12 is unable to install. Heres what i get when i try to install the firmware "the firmware file is oncorrect! Please get the firmware file again and make sure it is the correct firmware for this product"
https://www.netgear.com/support/product/DC112A%20(Zain).aspx#Firmware%20Version%201.0.0.12
Right now my Firmware Version 1.0.0.4 (Initial Release).Can you help me ?
I would like to this 1.0.012 firmare beacause :
Bug Fixes:
- Fixed the issue where the Cradle UI does not show 4G+ RAT icon, when the MHS is connected to two or more LTE CA Bands support.
