JayFray
Apr 11, 2016Aspirant
NETGEAR AirCard Smart Cradle (DC112A)
Hello, Where can I buy the NETGEAR AirCard Smart Cradle (DC112A) in Europe? Thanks.
voodoo69
Oct 16, 2016Aspirant
Netgear smart cradle dc112a -1Z1MES firmware Firmware Version 1.0.0.12
I try to update my smart cradle from Netgar site firmware version 1.0.0.12 is unable to install. Heres what i get when i try to install the firmware "the firmware file is oncorrect! Please get the firmware file again and make sure it is the correct firmware for this product"
https://www.netgear.com/support/product/DC112A%20(Zain).aspx#Firmware%20Version%201.0.0.12
Right now my Firmware Version 1.0.0.4 (Initial Release).
Can you help me ?
I would like to this 1.0.012 firmare beacause :
Bug Fixes:
- Fixed the issue where the Cradle UI does not show 4G+ RAT icon, when the MHS is connected to two or more LTE CA Bands support.
DarrenM
Oct 18, 2016Sr. NETGEAR Moderator
Hello voodoo69
you could try to update the router using TFTP
DarrenM
- voodoo69Oct 18, 2016Aspirant
I try Tftpd32.
Error in recv .
error code is 10054
- voodoo69Oct 19, 2016Aspirant
http://www.downloads.netgear.com/files/GDC/DC112A/DC112A_UMsrc_3Aug2015.pdf
22 -23 page
Where is this function in Zain model :
To :set up a WAN Internet connection with backup failover to your mobile hotspot"Tftps2I steps all 1 to 11tftp2.exe unable to get responses from the server ..- voodoo666Nov 11, 2016Aspirant
Don't work.
DC112A-V1.0.0.12_1.0.60 - DC112A-V1.0.0.12_1.0.60OOREDOO.chk work in station DC112A-1Z1MES(Zain)?
Auto update not detected this firmware only Firmware Version V1.0.0.4_1.0.60.
Why this update don't work in my DC112A Zain ?
http://kb.netgear.com/app/answers/detail/a_id/30803/~/dc112a-(zain)-firmware-version-1.0.0.12 .
Only
Previous Versions
Firmware Version 1.0.0.4 (Initial Release) work ;/.
