Moline
Dec 09, 2019Guide
Netgear equipment to use with a hotspot 2019
Hello all, Looking for help to find a newer solution to my home network. Currently I am using a Sprint Hotspot device(MV920VS) there is no cable or decent DSL service in my area. The hotspot is limi...
tsoetant
Dec 12, 2019NETGEAR Expert
Netgear M1 with LAN ethernet port should have all the features
Moline
Dec 19, 2019Guide
Found my own solution after buying a few other wireless routers/repeater. The one I found that is working well is a AMPEDWIRELESS High Power AC2200 WI-FI Range Extender (RE2200T), easy setup, found my hotspot device as soon as it was turned on. set my passwords for each frequency 2.4ghz, 5ghz and unit did its reset and now my wired pc's are connected to my hotspot.
