lsanford4064
Apr 17, 2022Follower
Netgear jet pack
We use a verizon jetpack for our internet. what is the best netgear wifi range extender to use with this wireless hot spot?
1 Reply
This section is given over to Mobile Routers, Hotspots & Modems. So it is a good place to get help with devices that might work with the verizon jetpack. But advice on range extenders is also available in the appropriate section:
WiFi Range Extenders & Nighthawk Mesh - NETGEAR Communities
The "best" choice depends on what you are trying to do. Things like how big an area you want to cover. You could also try plugging your needs into the filters on the product pages:
WiFi Range Extenders: Boost Your WiFi Range | NETGEAR
