DariusG_TMUS_SE
Sep 09, 2020Aspirant
Netgear LB 1120 Remote Login
I have read 2 previous threads and one said remote login into the device is not possible
and then this thread says it is possible
The device is using a T-Mobile sim card with an assigned Public Static IP.
Is it possible to remotely login into the router using the public static IP?
What configuration do I need to set ?
Thanks,
Darius
1 Reply
- DariusG_TMUS_SEAspirant
I have updated the device to the latest firmware and software update
