RdWarrior5126
Jan 23, 2022Aspirant
Netgear LB1120 : VoLTE support? hotspot usage?
Suggetions for best option for a 4g VoLTE supported mobile wifi hotspot?? Would Netgear model LB1120 be a good choice?? THANKS in advance for kind assistance.
JohnPeng
Jan 23, 2022NETGEAR Expert
LB1120 doesn't support VoLTE. I don't think we have WiFi hotspots support the feature. But you can find some fixed wireless products support this.
https://www.4gltemall.com/netgear-mvbr1517-4g-lte-voip-volte-router.html
Thanks
RdWarrior5126
Jan 24, 2022Aspirant
Thanks very much for reply. To clairify , Netgear does not currently have any cellular 4g VoLTE mobile hotspot products for sale, correct?
Due to my deployment locations , need a cellular 4g VoLTE compliant mobile hotspot. Any suggestions would be appreciated.
THANKS!
- JohnPengJan 25, 2022NETGEAR Expert
THANKS!
For VoLTE service, better to consult with the carrier that you plan to use. Sometimes, VoLTE service requires carrier support. BYOD may not work.
Thanks
