RdWarrior5126
Jan 23, 2022Aspirant
Netgear LB1120 : VoLTE support? hotspot usage?
Suggetions for best option for a 4g VoLTE supported mobile wifi hotspot?? Would Netgear model LB1120 be a good choice?? THANKS in advance for kind assistance.
RdWarrior5126
Jan 24, 2022Aspirant
Thanks very much for reply. To clairify , Netgear does not currently have any cellular 4g VoLTE mobile hotspot products for sale, correct?
Due to my deployment locations , need a cellular 4g VoLTE compliant mobile hotspot. Any suggestions would be appreciated.
THANKS!
JohnPeng
Jan 25, 2022NETGEAR Expert
THANKS!
For VoLTE service, better to consult with the carrier that you plan to use. Sometimes, VoLTE service requires carrier support. BYOD may not work.
Thanks
