showard1017's avatar
Apr 19, 2018
NETGEAR LB1120-100NAS 4G LTE Modem
Does the LB1120 use data when idle? IOW, if the main router is working does the LB1120 maintain an active data stream and use data minutes or does it only use data minutes when it takes over as the p...
