Deliric
Mar 17, 2022Follower
Netgear lb2120 connection with external antenna
I’ve bought a external antenna to boost the signal coz I live in a wacky area, the 4g plug that came with it is too big to fit into the modem, is there a way I can buy smth like an adapt or to make it fit? If so can you please guide me which one would work, thank you. I’ve tried going with the modem to nearby hardware stores and see if they have smth for it with no luck. Uk
1 Reply
- JohnPengNETGEAR Expert
LB2120's antenna connector is TS-9. Please check the connector on the antenna side and see whether we can find something online.
Thanks
