twintriode
Apr 12, 2018Aspirant
NETGEAR LTE Modem LB1120 compatibility question
Does the NETGEAR LTE Modem LB1120 work with StraightTalk or TracFone SIM card?
1 Reply
- JasonNNETGEAR Employee Retired
Hi twintriode,
You would have to check in with your ISP and see what bands they are using. As for the LB1120, the device supports the bands of LTE CAT 4 bands: B2,4,5,12 and UMTS DC-HSPA+ bands B2,5.
If your ISP does support those bands then you would have to have the right SIM card (3ff SIM card).
Please refer to the link below for the data sheet of the LB1120:
http://www.netgear.com/images/datasheet/mobile/LB1120.pdf
Please let me know if you have any other questions. :]
- Jason N
