Gango
Feb 14, 2024Aspirant
Netgear M1 1100-100 / Micro SD Card Slot
The M1 DOES NOT HAVA ANY SLOT FOR ANY SD CARDS!!!!!!
- GangoAspirant
All Netgear documents show a micro sd card slot for use but there are any in der EUS version.
Habe bought this M1 with the optionen to use a micro SD card but this ist possible!!!!
Is that the MR1100?
Some of these mobile routers are made for specific mobile operators. Maybe they leave that out of their devices.
