Retired_Member's avatar
Retired_Member
May 03, 2020
Netgear M1 mr1100-100 : WIFI, ETHERNET, USB-C RNDIS all stopped working
My Nighthawk M1 MR1100-100 does not broadcast the wifi signal anymore. This happened after I enabled wifi offloading. I have reset it several times by pressing on the reset button until I met with the message please don't turn off the device, connected it to PC through ethernet cable and usb c cable(RNDIS) but nothing works. Wifi is absent and the ethernet, RNDIS both fail to provide an ip. How I am supposed to setup the device if I can not connect any device to it? Thanks!
1 Reply
  • JohnPeng's avatar
    JohnPeng
    NETGEAR Expert
    Doing factory reset should resolve all these issues. Could you please advise what happened when you do factory reset by pressing the resetbutton?
    Thanks
