ocean917
Mar 04, 2020Follower
Netgear M1 MR1100 Ethernet Connection
Dear All,
Hoping I can find suggestion here.
I am using my Negear M1 by Wifi and Ethernet. at the same time I used wifi connection on ipad and Ethernet connection on my mac mini. The netgear M1 is powered by typec cable wtih QC 3.0 output device (without using battery).
Weir case happened. Everything is fine at a very begining. After I used for 20 mins, especially when I am not using my mac mini (but it didnt turn in sleep mode), the mac mini will become unable to online due to the sudden drop of the data donwload and upload to 0.2 m. Howver, it is no problem when I use ipad via wifi. My ipad can still use the wifi network at the same time. Then I tried to use wifi for my mac mini but still the same not working.
Thats mean the M1 wifi is wokring but the ethernet connection is very unstale. I am not sure it is setting problem or hardware problem.
Remarks I have turned on charge only function instead of tether and charge,
1 Reply
- Blanca_ONETGEAR Employee Retired
Hi ocean917
Welcome to NETGEAR Community!
May we please know the device SKU (e.g. MR1100-100NAS)? This can be checked on the box of the product or on the barcode label
What is the firmware version?
Kindly disable Ethernet Standby. Here's how: Access MR1100 UI > Settings > Setup > Mobile Router Setup > Ethernet Standby (disabled or 2 minutes) > Apply
Blanca
Community Team
