Den123
Jun 18, 2022Follower
Netgear m1 no battery in
Hi all I leave my Netgear m1 plugged in to the mains all the time is it ok to leave the battery in it or take battery out thank you
Jun 18, 2022Guru - Experienced User
I think I remember reading that if you're planning on running it 24/7, to remove the battery.
you might get better help in the mobile routers forum next time
https://community.netgear.com/t5/Mobile-Routers-Hotspots-Modems/bd-p/aircard
