786Puru
Sep 26, 2022Follower
Netgear M1 not connected to the router.
Hi Folks! I hope everyone is doing well. The reason for writing is I was trying to setup my visible sim to netgear M1 router. But, It’s saying no devices found or insert sim card . Even though the si...
W1lliam
Sep 28, 2022Virtuoso
6420B basically is a locked model, you would need to check whether or not this device is unlocked or you are using a SIM card that is allowed to have hotspot installed. APN needs to be set for that particular SIM card, different from one carrier to another if your device is unlocked.
