Q8cracker
Jul 29, 2017Guide
Netgear M1 reboot issue Resolved!
Netgear M1 reboot issue Resolved! i found the real problem that relates to router reboot "randomly reboot" was from your country network band , Tut: 1- go to admin page 2- sign in 3- go to set...
UK-based
Dec 13, 2017Luminary
This might not apply to everyone with the reboot issues, but it may help some of you.
I'm using my M1 as my main home router but having the flexibility to disconnect it from my network when I want internet access on my travels. For use at home I wanted to remove the battery and power it solely from the supplied 2A mains charger.I have an Ethernet connection from the M1 to an unmanaged Gigabit Ethernet switch, to which I have 2 access points attached for extending my Wi-Fi coverage throughout the house (the Wi-Fi coverage from the M1 isn't very extensive). I also have an external Poynting XPOL-A0001 omni 2x2 antenna attached to the M1 via a couple of short SMA to TS-9 pigtail adapter leads, in order to achieve a strong (5 bar) signal into the M1.
However, the M1 constantly rebooted, and the reboots were often triggered by some activity like starting a file download. If I put the battery back in and kept the charger connected, it didn't reboot, but this wasn't ideal because it meant removing the charger when the battery was 100% charged and then replacing it before the battery got too low!
I read other threads suggesting replacing the mains charger with a more powerful one, so I purchased a good quality charger with Qualcomm Quick Charge 3.0 technology - this is backwards compatible with the Qualcomm Quick Charge 2.0 enabled chip in the M1 and is able to supply 2.4A. I also replaced the charging cable with a high quality one from the same manufacturer. Since doing this, the M1 interface reports that the session has only been disconnected once in 5 days, and this might be the mobile network provider that caused the session to be disconnected rather than the M1.
When I check the M1 browser interface Settings > Diagnostics under the Device heading I can see that the "Battery Charge Status" is indicated as "QuickCharge", so it has clearly recognised this technology in the charger. Obviously, supplying the higher amperage of 2.4A does raise the temperature of the unit, which can also be seen in the Settings > Diagnostics: Device section. My M1 was reaching 41degC when performing heavy downloads, dropping to around 36degC when idle. In order to reduce this, I removed the battery compartment cover and raised the M1 off the surface a few centimeters to allow a flow of air into the battery compartment. I also placed a old CPU heat sink on the top of the unit (with a bit of cling film between to avoid damaging the screen). The heat sink is probably "overkill" but I managed to drop the temperature range by about 5degC (31-36degC), which I guess should be acceptable.
So if you too are using the M1 as a static router in your home, this might be a solution for you. However, please be aware that you will be doing this at your own risk. I've no idea how using a different charger from the one suplied would affect warranty, or for that matter the lifespan of the M1. There are many poor quality mains chargers on the market that can damage equipment. It's up to you to do the research to make sure you have a reliable brand.
Good luck!
Gbear1984
Feb 17, 2018Tutor
Hi All,
Not sure it helps anyone, but here is my feedback. I have tried the above settings and I have definitely gotten some improvement. I definitely regret updating the firmware as it was perfectly fine.
I have actually bring down the screen brightness as well, just so that i can bring down the temperature. From that i got longer usage.
But what i suspect here is that if the temperature keeps going beyong 41 deg, it will reboot and not allow you to start till it cools down. but what i did was just taking out the battery and inserted in back again.
Any idea, where or how i can get hold of the older firmwares? i really want to flash it manually as I could see from my admin page that i can upload firmware and restore it.
Thanks!
- winger13Mar 10, 2018Guide
I ran my tests which shot the temperature to 50 degrees Celcius and the Nighthawk continued functioning (no reboots)
