Q8cracker
Jul 29, 2017Guide
Netgear M1 reboot issue Resolved!
Netgear M1 reboot issue Resolved! i found the real problem that relates to router reboot "randomly reboot" was from your country network band , Tut: 1- go to admin page 2- sign in 3- go to set...
Gbear1984
Feb 17, 2018Tutor
Hi All,
Not sure it helps anyone, but here is my feedback. I have tried the above settings and I have definitely gotten some improvement. I definitely regret updating the firmware as it was perfectly fine.
I have actually bring down the screen brightness as well, just so that i can bring down the temperature. From that i got longer usage.
But what i suspect here is that if the temperature keeps going beyong 41 deg, it will reboot and not allow you to start till it cools down. but what i did was just taking out the battery and inserted in back again.
Any idea, where or how i can get hold of the older firmwares? i really want to flash it manually as I could see from my admin page that i can upload firmware and restore it.
Thanks!
winger13
Mar 10, 2018Guide
I ran my tests which shot the temperature to 50 degrees Celcius and the Nighthawk continued functioning (no reboots)
