ENGA7R's avatar
ENGA7R
NETGEAR M1 RESTARTS ALWAYS
MY NETGEAR M1 (MR1100-100 ) KEEPS SHUTTING DOWN AND RESTARTS AUTOMATICALLY !
SKU MODEL MR-1100-1RDMES
  • JohnPeng's avatar
    JohnPeng
    NETGEAR Expert
    Please provide the FW and PRI version on the device now. I will check whether we have new updates for the device.
    Thanks
    • ENGA7R's avatar
      ENGA7R
      FIRMWARE VERSION :  NTG9X50C_12.06.03.00
      thanks bro ..
  • JohnPeng's avatar
    JohnPeng
    NETGEAR Expert
    Did you try to do a factory reset and see whether this helps?
    You can find the hard reset button near the micro-SD card slot.
    Thanks
