Q8cracker
Jul 13, 2017Guide
Netgear M1 still reboot !
Netgear M1 still reboot when i using it more than 10 mins! if started to download something or try speedtest app etc.. it's going to reboot it self and sometimes shutdown then should to release the ba...
DarrenM
Jul 18, 2017Sr. NETGEAR Moderator
Hello Q8cracker
I suggest contacting our support if there is a hardware issue they will be able to help you.
http://www.netgear.com/support/contact.aspx
DarrenM
Teewee4134
Sep 10, 2017Guide
I am in the same boat as Q8cracker
I brought my Router on Ebay. Contacted Netgear about the reboot issue. netgear lookup my device serial number and basically said that the router was sold thru Telstra and I will have to contact them.
I call Telstra to inquire about any upcoming firmware for Nighthawk M1. I explained that am not in Australia and the tech said sorry cannot help you because you are outside the country.
