Pablococito
Dec 07, 2021Aspirant
Netgear M1100 keeps freezing and not broadcasting.
I have a M1100 router that has worked perfectly up until the other day.. one morning I went to use it and it wasn’t showing up on the wifi list. I restarted it and no change. I reset it holding the ba...
Dec 07, 2021Guru - Experienced User
IF your referring to the MR1100, FW for this unit is kept here:
https://www.netgear.com/support/product/MR1100.aspx#download
As a full power OFF of the unit for 1 minute or more then plug back in been performed?
- PablococitoDec 15, 2021AspirantHow would I install that FW on the M1100? I can’t seem to connect to the device at all.
- JohnPengDec 15, 2021NETGEAR Expert
This seems a HW failure. Please do a factory reset and see whether the device can be rebooted.
Thanks
