Pablococito
Dec 07, 2021Aspirant
Netgear M1100 keeps freezing and not broadcasting.
I have a M1100 router that has worked perfectly up until the other day.. one morning I went to use it and it wasn’t showing up on the wifi list. I restarted it and no change. I reset it holding the ba...
Pablococito
Dec 15, 2021Aspirant
How would I install that FW on the M1100? I can’t seem to connect to the device at all.
JohnPeng
Dec 15, 2021NETGEAR Expert
This seems a HW failure. Please do a factory reset and see whether the device can be rebooted.
Thanks
