ultrakiasu
Jul 03, 2023Follower
Netgear M2 root access?
I had seen old article here on gaining access to root prompt and perform certain iptables commands on older M1. I need to do similar commands on Netgear M2 (MR2100), but unable to get it. Any he...
Parterblockerso
Jul 03, 2023Aspirant
The Netgear M2 is a mobile hotspot device that provides best internet connectivity. As a user, you typically don't have root access to the Netgear M2 device. The manufacturer restricts access to the root or administrative functions of the device to maintain its security and stability.
