MichaelDam
May 19, 2022Follower
Netgear M2 Router
Hello I bought a new M2 NightHawk router. After an update my router is showing a weard icon. If I enable tethering over USB and disable the wireless network, my router show the following: A grey d...
May 19, 2022Guru - Experienced User
have you logged into the app to check it? I don't have one to compare but it could just be a notice that you're using tethering.
