EmmTwo's avatar
EmmTwo
Tutor
Jul 07, 2022
Netgear M2 unstable Internet Connection
I used to own an M1 mobile router, I was very happy with. When that one died I went for the newer M2 and problems started. Sonos speakers (wired & wifi) started intermttently dropping out (losing connection to streaming services, especially Apple Music) also streaming apps on mobile devices (iphone/ipad) started to show SSL errors (intermittent connection failures) when playing (especially Apple Music). This never happened with the M1. Other internet services (youtube, browsing, gaming) are fine … Any advice?
  • Is it just the M2 by itself or do you have it connected to a router?
      • plemans's avatar
        Guru
        Are you using icloud relay or private mac/ip address on ios devices? If so, disable that and try it
