TeeJay74
Jun 15, 2020Virtuoso
Netgear M5 EU - user experiences
Hi, I have been fieldtesting this device for few days now. Does anyone else have user experiences of this device by now?
TeeJay74
Oct 31, 2020Virtuoso
Here pictures from yesterday, I was fieldtesting M5 EU at Oulu, Northern Finland. DNA 5G basestation(Huawei RAN).
5G ENDC combo: B28@10MHz+B3@20MHz+B7@20MHz+B1@20MHz+n78@100MHz.
abhi093
May 07, 2021Aspirant
Do you have a technical datasheet where it says about the bands it can aggregate.?? I am not talking about the default datasheet
- TeeJay74May 07, 2021Virtuoso
Well, some CA combo support lists do exist, but these are not public data. Do you have some specific CA combo support question in mind? Generally speaking M5 EU CA combo support is still evolving and level of CA combo support is wide. I have been using device with 5CC LTE+NR and latest firmware 12.03.09.00 PRI 03.03 Firmware build date: 2021/04/09 supports 6CC LTE+NR.
- abhi093May 07, 2021AspirantThanks, looking for the below combos
40A+40A,
40c
3A+40A
3A+40A+40A
1A+3A+40A+40A
N3+3 , N40+40, n3+40, N40+3 - TeeJay74May 07, 2021Virtuoso
40A+40A, :YES
40c :YES
3A+40A :YES
3A+40A+40A :YES
1A+3A+40A+40A: NO
N3+3 :NO
N40+40 :NO
n3+40 :NO
N40+3 :NOThis is my opinion to asked CA combo support question. Please keep in mind this may not fully represent what the latest firmware could have. RAN side must be properly configured too. Always a good method to capture UE Capability message's from specified network and decode these to see what's happening between network and terminal.
- abhi093May 07, 2021AspirantOk Thanks!!
Does Netgear M5 supports Dynamic Spectrum Sharing DSS?? It is a x55 modem , I believe it should.. buy need your opinion.
What application are you using to decode the band transmission information between RAN and UE ?? - TeeJay74May 07, 2021Virtuoso
I think DSS was enabled in 10.29.11.00 PRI 02.17 version Build date 2020/11/26.. QCAT tools for example can be used for log analysis,
- abhi093May 08, 2021AspirantThanks for you reply.
In at command of MR5200 it shows the mmWave bands are all 00000000000000. Does MR5200 supports mmWave and is disabled now , which can be enabled by Netgear later by firmware updates?? - TeeJay74May 08, 2021Virtuoso
MR5200-100EUS, what is called as EU-model does not have Qualcomm mmWave-antenna module inside. Actually at this moment EU area commercial terminal support for mmWave is extremely rare.
- abhi093May 08, 2021AspirantThere is one from Poland Play telecom. ZTE MC7010. Supports n257 and n258 of mmWave in Europe
Actually I have done some experiments with ZTE MC7010 (Poland model)in Finland and it did not work well. Bad problems with n78 downlink with all Finnish operators..
- abhi093May 08, 2021AspirantOh ok. Thanks for your reply. I sent you private message
