TeeJay74
Jun 15, 2020Virtuoso
Netgear M5 EU - user experiences
Hi, I have been fieldtesting this device for few days now. Does anyone else have user experiences of this device by now?
TeeJay74
May 07, 2021Virtuoso
I think DSS was enabled in 10.29.11.00 PRI 02.17 version Build date 2020/11/26.. QCAT tools for example can be used for log analysis,
abhi093
May 08, 2021Aspirant
Thanks for you reply.
In at command of MR5200 it shows the mmWave bands are all 00000000000000. Does MR5200 supports mmWave and is disabled now , which can be enabled by Netgear later by firmware updates??
- TeeJay74May 08, 2021Virtuoso
MR5200-100EUS, what is called as EU-model does not have Qualcomm mmWave-antenna module inside. Actually at this moment EU area commercial terminal support for mmWave is extremely rare.
- abhi093May 08, 2021AspirantThere is one from Poland Play telecom. ZTE MC7010. Supports n257 and n258 of mmWave in Europe
Actually I have done some experiments with ZTE MC7010 (Poland model)in Finland and it did not work well. Bad problems with n78 downlink with all Finnish operators..
- abhi093May 08, 2021AspirantOh ok. Thanks for your reply. I sent you private message
