Rvision
Aug 11, 2023Aspirant
Netgear M5 (MR5200) Internal Antennas Not Working
Advance thanks for any input, My Nighthawk fell off a shelf from pretty high up and now the internal antennas do not pickup any cell signal (searching📵) but if I connect external antennas every...
Rvision
Thanks thats really helpful. I'd not found that article.
And yes it does have the QTM525 antenna module, mentioned in the diagram and if you look at the picture below at the bottom left, it's mounted vertically 😁😁 So it's probably just got knocked out of the socket in the drop or damaged, in which case I can replace it..
Rvision
More info here if anyone need in future from an FCC report.. looks like multiple antenna modules and array configuration on the PCB for low band..
https://fcc.report/FCC-ID/PY321100529/5665583.pdf
