bary35
May 16, 2023Follower
Netgear M5/M6 cooling stand?
Hi, I have an MR6150 inbound. I will be using this outdoor, and it may be subjected summer temps (Midwest US) and direct sunlight. It looks like the M5 and M6 are basically the same size? Does anyone...
May 16, 2023Guru - Experienced User
I could do your best to keep it out of direct sunlight. Certain plastics break down/weaken under UV light from the sun. Plus shade will help it from getting to hot.
