RS28
Nov 03, 2023Aspirant
Netgear M6 Pro MR6450 vs MR6550 Very Slow Download Speeds firmware NTGX65_12.01.31.00
I have both of these routers in the U.K Netgear M6 Pro MR6550 Unlocked (US) version Netgear M6 Pro MR6450 Unlocked getting very poor downloads & upload speeds compared to MR6450 on Three UK 5G Net...
JohnPeng
Nov 05, 2023NETGEAR Expert
RS28 wrote:
I even had a MR6500-1TLAUS on Telstra Version which was working perfect on the same Three UK 5G network was getting 5G speeds close to MR6450
MR6550-100PAS - working with No 5G speeds
MR6450-100EUS - working perfect with 5G
MR6500-1TLAUS - working perfect with 5G
I assumed the MR6550 was supposed to be more superior with the most network bands has advertised by Netgear and latest 2023 release model
could you please let me know is there any firmware in works to fix the issue the same which was done on did other versions please JohnPeng
MR6550-100PAS is targeting US and Canadian carriers, the band and combo supports are different from Telstra and EU SKU. MR6550-100PAS can support roaming to EMEA countries, but the device performance will be compatible with SKUs targeting EMEA contries.
Thanks
John
RS28
Nov 06, 2023Aspirant
JohnPeng
Thanks for replying MR6550-100PAS so it can support roaming to EMEA countries that is including UK too but the device doesn’t perform has it should do I’m getting No 5G speeds at all on the Three UK 5G Network which is biggest 5G network provider in the United Kingdom although it show up on the router LCD connected to 5G but No 5G Speeds maximum speeds I’m getting are 50-60mb download compared to 600mbs + on the other Netgear M6 Pro MR6450 MR6500 routers even on the Netgear M1 I was getting 150mb Netgear claim the MR6550 can roam over 125 countries can you please check via JSON file
what can be the issue
- RS28Nov 06, 2023AspirantJohnPeng this MR6550-100PAS cost $999 and claims it is a “unlocked model” and can roam in over 125+ countries as Netgear advertises it on the website then surely it should work in the United Kingdom, which is a major country in Europe
MR6550-100PAS has the most 4G 5G network bands show on Netgear website specifications even more than MR6450-100EUS version
The MR6500-1TLAUS is targeting a Australian Telstra carrier only and doesn’t specify it’s a“unlocked model” has the lowest least 4G 5G bands but still it works perfect on 5G in U.K unlike the MR6550-100PAS which Netgear claims it’s a “unlocked model ” and covers 125+ countries and yet it doesn’t work in the United Kingdom on the UK biggest 5G Network Provider “Three” Why does it show on the MR6550 router it’s connected to 5G but I don’t get the 5G download speeds only very low 4G speeds it doesn’t make any sense I believe this issue needs to be fixed via a firmware update- RS28Nov 06, 2023AspirantJohnPeng I sent both json files for Netgear M6 Pros MR6550-100PAS and MR6450-100EUS to email jopeng@netgear.com
Both on same SIM card “Three U.K 5G Network”
ID RS28- stavsterNov 08, 2023Aspirant
I have just recently purchased an MR6450 M6 Pro unlocked version in the last week. I too am having problems on the Three network in the UK with the device. Generally (apart from the odd exception, see below) really poor speeds, both in normal CGNAT mode and IP Passthrough. Tried both.
Seems to fluctuate enormously.
However at a couple of points during the last week I have got super speed from the device on Three, running exactly the same config parameters as say for instance now.
Looking at the device connection info from the admin portal, I am always connecting at "5GSUB6" to the Three mast which is near my house. I think this is the best 5G operational mode. / frequency Three supports at the moment. At least in my area.
Here is the oddity: (Couldnt complain with this I was shell shocked when it came through. And repeated the test multple times for a few hours on that day with similar results)
My speedtest result from a few days ago : (740M download, 83M Upload) - Speedtest was performed connecting via Wifi 6E both on 5ghz and 6ghz directly to the MR6450.
https://www.speedtest.net/result/15472301035
However as soon as I rebooted the router the next time (with the same config, nothing changed) and connecting with no real fluctuation in quality and mode to the Three 5G mast I am consistently getting speeds like this. (Still "5GSUB6")
https://www.speedtest.net/result/15483806830
Occasionally on a few reboots on various days I might get 350M download 40 - 60M upload but this is very rare. And then on a power off and reconnect it will just drop to 20 - 40M again.
It really just seems hit or miss (more often than not miss) if I get a decent speed out of it like the 750M download test I posted further up the post. If anyone has any feedback / suggestions or if Netgear would like me to provide logs I am happy to do so.
Thanks
