RS28
Nov 03, 2023Aspirant
Netgear M6 Pro MR6450 vs MR6550 Very Slow Download Speeds firmware NTGX65_12.01.31.00
I have both of these routers in the U.K Netgear M6 Pro MR6550 Unlocked (US) version Netgear M6 Pro MR6450 Unlocked getting very poor downloads & upload speeds compared to MR6450 on Three UK 5G Net...
RS28
Nov 04, 2023Aspirant
I am connected to Three 5G network WIFI on the MR6550, but the download speed are like 4G or even lower I tried both 2.4 ghz and 5G WiFi bands
in the Netgear app diagnostic section under Current Radio Band is - LTE B3
5G RSRP - N/A
5G RSRQ - N/A
5G RS-SNR - N/A
The above doesn’t change at all always stay showing N/A on the MR6550
whereas on the MR6450 Current Radio Band is LTE B1 and 5G RSRP 5G RSRQ 5G RS-SNR are showing digits numbers fluctuating the download speeds are terrible on the MR6550 can anyone please help me what is wrong with this router
The MR6450 is superb very high download
Three Network 5G mast tower is literally only 150 ft away from my house quite close
5G RSRP - N/A
5G RSRQ - N/A
5G RS-SNR - N/A
Jtp77
Apr 17, 2024Initiate
Sounds like your router doesn’t have the correct N band to connect to available N band in your area with subscriber.
Bought the 6500 ATT version. Says unlocked and works with T-Mobile. That is correct. Works with T-Mobile only at LTE speeds not 5G. T-Mobile uses N71. Which this device doesn’t have.
Now need to sell and upgrade to the MR6550 which has the N71.
