Tmaciasm
Apr 22, 2023Initiate
Netgear m6 Pro MR6500 hot spot OVER HEATING
Why is my unit overheating with battery installed while using or charging it. This is my 3rd unit to do the exact overheating. I want to know the fix to this problem.
JohnPeng
Apr 23, 2023NETGEAR Expert
1. Please capture model.json file and send PM to me
2. Please detail your network setup.
- How many WiFi clients
- Is Ethernet port enabled and speed
- What is connected to Ethernet port
Thanks
John
Ak93
Oct 27, 2023Aspirant
Hi I have heating issue with my M6 Pro MR6450 from day one even after the last update the issue still not solved.
Because of heating the battery drain so fast. the heating issue presents with both options battery and plug in cable.
- Blanca_ONov 15, 2023NETGEAR Employee Retired
Hi, All,
Please be informed that we have released firmware
FW v12.01.47.00 for MR6550-100PAS and MR6150-100NAS
FW v12.01.48.00 for MR6450-100EUS, MR6150-100EUS and MR6550-100APS
This release includes the following:- Improving the thermal performance
- Introducing some new UI messages on LCD to mitigate with the thermal concerns
- Improve overall performance , resolving some unexpected Rebooting
- Improve ETH Performance (speed)
- Not Powering On
- Intermittent Charging
Other SKUs will follow in the next few days as it requires testing by the carriers.
Blanca
Community Team- Ak93Dec 05, 2023AspirantI already downloaded the latest update
and disabled the Ethernet.
Usually I connected 2 devices and sometimes 4- JohnPengDec 06, 2023NETGEAR Expert
Usually I connected 2 devices and sometimes 4Could you please provide some feedback on using FW 12.01.48.00 to see whether you can see any improvement for the heated issue? You can use the device same way as how you used it before. Your comments will be valuable to us.
Thanks
