Tmaciasm
Apr 22, 2023Initiate
Netgear m6 Pro MR6500 hot spot OVER HEATING
Why is my unit overheating with battery installed while using or charging it. This is my 3rd unit to do the exact overheating. I want to know the fix to this problem.
Ak93
Oct 27, 2023Aspirant
Hi I have heating issue with my M6 Pro MR6450 from day one even after the last update the issue still not solved.
Because of heating the battery drain so fast. the heating issue presents with both options battery and plug in cable.
