Tmaciasm
Apr 23, 2023Initiate
Netgear m6 Pro MR6500 hot spot OVER HEATING
Why is my unit overheating with battery installed while using or charging it. This is my 3rd unit to do the exact overheating. I want to know the fix to this problem.
Lori90
Jul 28, 2024Tutor
The firmware is up to date. There's only 1 device connected and it's out in the open. It's my third one due to the battery. It should not be overheating with 1 device connected. Within 10 mins it says heat mode.
totorotenten
Jul 28, 2024Tutor
Lori90 could you please share your model SKU, thanks
