Maori232323
Jul 26, 2024Follower
Netgear M6 Pro not charging
Hello My netgear m6 pro won’t charge with the battery in. I just get a message saying “battery level too low. Charge for a few minutes before powering on”. However I have left it over 24 hours & it...
Jul 29, 2024Guru - Experienced User
Is it in warranty?
Some lithium batteries won't charge if they drop below a certain voltage.
You could pull the battery out and check its actual voltage. it could be bad, or to low to start charging.
I've seen that happen and there's ways around it but they void the warranty and can be dangerous.
