YoungJo
Feb 20, 2025Aspirant
Netgear M7 pro unable to connect 5G in S.KOREA
Model: M7 pro (#MR7400) Firmware Version: NTGX75_10.03.22.01 Software Version: MR7400-1A1NAS_02.11 Hardware Version: 1.0 PRI Version: 02.11 My device is an AT&T model but is carrier unlocked. ...
JohnPeng
Feb 20, 2025NETGEAR Expert
For NSA not working in S Korea, that is because ATT M7 doesn't support the following LTE bands: 1, 3, 5, 7.
For your case, it may be better to get Telstra MR7500 for using in your country. Or you have to wait for next MR with 5G SA enabled.
YoungJo
According to the M7 Pro manual, the Mobile Band Specifications section states that the Nighthawk M7 Pro (model MR7400) supports the following bands:
4G/LTE bands: 1, 2, 3, 4, 5, 7, 12, 14, 28, 29, 30, 40, 46, 48, 66
5G NR bands: n2, n5, n12, n14, n28, n29, n30, n48, n66, n77, n78
Since it explicitly lists LTE bands 1, 3, 5, and 7 as supported, am I misunderstanding something?
And is there a possibility that the M7 Pro could support 5G SA through a firmware update?
JohnPeng
JohnPeng
