YoungJo
Feb 20, 2025Aspirant
Netgear M7 pro unable to connect 5G in S.KOREA
Model: M7 pro (#MR7400) Firmware Version: NTGX75_10.03.22.01 Software Version: MR7400-1A1NAS_02.11 Hardware Version: 1.0 PRI Version: 02.11 My device is an AT&T model but is carrier unlocked. ...
W1lliam
Feb 24, 2025Virtuoso
rcpax I did the first OTA upgrade here, it was buggy on very first FW and then fixes some bugs in current FW, so I assume ATT is unblocking OTA for non-ATT network/sim for this particular model.
YoungJo
Feb 24, 2025Aspirant
I agree.
As soon as I received the device in Korea, a firmware update was performed.
When I quickly compared the Model.json file you provided, W1lliam, with mine, I noticed that I only have 0: All and 1: LTE All under BandRegion, while you have 2: Full Bands.
Did you modify this yourself? Or did it appear after an update?
I'll take a closer look and ask you about the differences.
- W1lliamFeb 24, 2025Virtuoso
YoungJo Yes, adding band region option with AT commands, also specifying which band region as default. It does not allow you to pick up available band region options from Web interface, not sure about App. It is working here with default settings, so your problem should not has dependency with this band region options.
- YoungJoFeb 24, 2025Aspirant
Could you let me know how you set index 2 as the default after adding the Band Region option?
In my case, I can't select it through the Web UI, but when using the Netgear Mobile App, I can see and select the added Band Region.
However, since index 0: All already includes all available bands, including NR78 NSA, it does seem like the issue is unrelated to the Band Region option, as you mentioned.
