Ggold
Aug 17, 2016Follower
Netgear MBR1210 in Ghana
Hello everyone… I am living in Ghana for a year. All Internet access is via Cell signal. For the past several weeks I have been writing to technology friends all over the world for info about some so...
jguerdat
Aug 18, 2016Guru
Sorry, you're in the wrong Netgear forum - this one is for Arlo cameras. Try starting here:
https://www.netgear.com/support/product/MBR1210-1BMCNS.aspx?cid=wmt_netgear_organic
I think you want to use the forums found here:
https://community.netgear.com/t5/AirCard-LTE-Hotspots-Gateways/bd-p/aircard?cid=wmt_netgear_organic
- DarrenMAug 19, 2016Sr. NETGEAR Moderator
Hello Ggold
This is a product supported through the ISP it may work on other GSM networks but it is a modem specifically made for use with Bell.
DarrenM
