StefD74FR
Nov 24, 2020Aspirant
Netgear Mobile App cannot find my nighthawk M2 router
Hi after upgrading iOs the Netgear Mobile Application installed onto both my iPad and iPhone cannt see the router anymore. It tries toi detect then I get an error massage stating Router cannot be...
- Nov 25, 2020
Hi StefD74FR
For devices on iOS 14, Apple is mandating that apps like the Nighthawk, Orbi and Mobile apps must ask permission to communicate with the devices on your network.
By allowing access, you let the app connect to your NETGEAR router. Granting access is also necessary for the full functionality of the apps.
To enable local network permission:
- Launch the Settings app on your iOS device.
- Select the Mobile App from your apps list.
- Slide the Local Network slider to the right to enable this feature.
Blanca
Community Team
StefD74FR
Nov 25, 2020Aspirant
Thanks Blanca - please confirm what you mean by "granting local network access" as I cannot figure this out.
FYI I can access router's parameters using Safari / http but the app states that I am not connected to any Netgear device
Blanca_O
Nov 25, 2020NETGEAR Employee Retired
Hi StefD74FR
Blanca
Community Team
- StefD74FRNov 25, 2020Aspirant
All fine. Many thanks
