Tomtus
Sep 20, 2022Aspirant
Netgear Model MR 1100
Hi, I have changed data provider on my mobile hotspot and I'm looking to change the pin code as currently it doesn't work. The eb address http://m.home/ which is listed on Netgear site is not accessible and when using the Ip address it just goes onto my home router(I'm using the mobile hotspot at another location. Does anyone have a solution on this?
1 Reply
- TomtusAspirant
Just wanted to give a bit more colour on my request. I put in the new sim card and was asked to complete the setup on the mobile router and change the pin code. However, I'm not able to login to the gui at http://m.home to unlock the pin and I'm guessing this is because the mobile router is not connected. Does anyone know what I can do here? Thx for any replies.
