Mattylite6
Aug 01, 2020Follower
Netgear modem model lb1120 has a blinking amber power light and one green middle internet strength l
Modem has a blinking amber light and the third of the five internet strength lights is solid green. How do I fix it?
1 Reply
- Blanca_ONETGEAR Employee Retired
Hi Mattylite6
Welcome to NETGEAR Community!
If you have the power blinking amber and third bar is lit up green, the micro SIM card out or not correctly installed. Kindly check the SIM card - remove and re-insert the SIM card.
Reference:
https://www.downloads.netgear.com/files/GDC/LB1120/LB112x_UM_EN.pdf [page 85 - 86]
Blanca
Community Team
