Abdul_3ziz
Aug 21, 2019Star
NETGEAR MR 1100-100 EUS not showing in Wi-Fi list in Windows 10
Hi there, As you can see from the subject field that NETGEAR MR 1100-100 EUS not showing in Wi-Fi list in Windows 10 althouth I have updated the Wi-Fi drivers in windows but still not showig in t...
Blanca_O
Aug 22, 2019NETGEAR Employee Retired
Hi Abdul_3ziz
Welcome to NETGEAR Community!
Does your Windows 10 computer detect other WiFi network? How far or close are you from the MR1100 when you scan for WiFi network?
What about other Wireless devices? Can it detect MR1100 WiFi network?
Blanca
Community Team
Abdul_3ziz
Aug 23, 2019Star
hI Blanca_O
I do appreciate your time and support, kindly find out my reply as below:
- Yes, it's able to detect other WiFi networks
- it's very close to my Laptop, and MR1100 esxist in the same room, althouth the WiFi range set to "Long"
- yes, it's discovirable for smartdevices
Hints:
I have re-installed the WiFi Adapter drivers but still not being discovered by Widnows 10m to be honest I don't want to reset MR1100 due to some settings.
looking for a suggestions.
Thank you
- Blanca_OAug 26, 2019NETGEAR Employee Retired
Hi Abdul_3ziz
Thank you for responding.
Since other wireless devices (Smart devices) detect the MR1100 WiFi network then we can say that it broadcast signal.
Please try to manually add the network to your Windows 10 computer.
Blanca
Community Team- Blanca_OAug 29, 2019NETGEAR Employee Retired
Hi Abdul_3ziz
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
Blanca
Hi Abdul_3ziz
Kindly access MR1100 router settings and change the channel.
Blanca
Community Team
- Abdul_3zizAug 29, 2019Star
Hi Blanca_O
I have followed the steps mentioned via https://pureinfotech.com/add-new-wifi-network-windows-10/ but still not showing in the WiFi lists, What do you suggest?
Regards
- Troy_TAug 31, 2019Aspirant
Abdul_3ziz wrote:Hi Blanca_O
I have followed the steps mentioned via https://pureinfotech.com/add-new-wifi-network-windows-10/ Mycfavisit but still not showing in the WiFi lists, What do you suggest?
Regards
Since other wireless devices (Smart devices) detect the MR1100 WiFi network then we can say that it broadcast signal. Please try to manually add the network to your Windows 10 computer.
