Abdul_3ziz
Aug 21, 2019Star
NETGEAR MR 1100-100 EUS not showing in Wi-Fi list in Windows 10
Hi there, As you can see from the subject field that NETGEAR MR 1100-100 EUS not showing in Wi-Fi list in Windows 10 althouth I have updated the Wi-Fi drivers in windows but still not showig in t...
Abdul_3ziz
Aug 23, 2019Star
hI Blanca_O
I do appreciate your time and support, kindly find out my reply as below:
Does your Windows 10 computer detect other WiFi network?
- Yes, it's able to detect other WiFi networks
How far or close are you from the MR1100 when you scan for WiFi network?
- it's very close to my Laptop, and MR1100 esxist in the same room, althouth the WiFi range set to "Long"
What about other Wireless devices? Can it detect MR1100 WiFi network?
- yes, it's discovirable for smartdevices
Hints:
I have re-installed the WiFi Adapter drivers but still not being discovered by Widnows 10m to be honest I don't want to reset MR1100 due to some settings.
looking for a suggestions.
Thank you
Blanca_O
Aug 26, 2019NETGEAR Employee Retired
Hi Abdul_3ziz
Thank you for responding.
Since other wireless devices (Smart devices) detect the MR1100 WiFi network then we can say that it broadcast signal.
Please try to manually add the network to your Windows 10 computer.
Blanca
Community Team
- Blanca_OAug 29, 2019NETGEAR Employee Retired
Hi Abdul_3ziz
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
Blanca
Community Team- Blanca_OAug 29, 2019NETGEAR Employee Retired
Hi Abdul_3ziz
Kindly access MR1100 router settings and change the channel.
Blanca
Community Team- Abdul_3zizAug 31, 2019Star
Hi Blanca_O
Are you refering to the attached filed in router settings? if Yes which number I have to select?
Regards
- Abdul_3zizAug 29, 2019Star
Hi Blanca_O
I have followed the steps mentioned via https://pureinfotech.com/add-new-wifi-network-windows-10/ but still not showing in the WiFi lists, What do you suggest?
Regards
- Troy_TAug 31, 2019Aspirant
Abdul_3ziz wrote:Hi Blanca_O
I have followed the steps mentioned via https://pureinfotech.com/add-new-wifi-network-windows-10/ Mycfavisit but still not showing in the WiFi lists, What do you suggest?
Regards
Since other wireless devices (Smart devices) detect the MR1100 WiFi network then we can say that it broadcast signal. Please try to manually add the network to your Windows 10 computer.
Hi Troy_T
Thank you for getting back to me, although I have followed the said URL but not working, Could you please give me a way of adding the network manually?
Regards
