youngone89
Feb 13, 2024Follower
Netgear MR1100 - power Constantly cycling off and on
We have a router that has not been used for a while and it is needed urgently. I thought the battery was dead as it turns on for a few seconds then turns off immediately and the cycle continues. S...
Feb 14, 2024Guru - Experienced User
1. try a different power supply. The battery might be dead and the power supply not putting out enough to charge it or boot up the device.
2. If something in the firmware/software is causing the boot loop, maybe a factory reset can help. Have you tried a hardware factory reset?
