Deek56
Mar 07, 2022Aspirant
Netgear MR1100-100
My Nighthawk has suddenly stopped charging, a bit strange as it seems to have happened just when my support had ended, has anyone had a similar issue and a fix?
Blanca_O
Mar 14, 2022NETGEAR Employee Retired
Hi Deek56
Welcome to NETGEAR Community!
When you try to charge the device, what shows in the LCD UI?
Can you still power on the device with the power adapter only without inserting the battery?
This link may help you out:
What do I do if my Netgear Mobile Hotspot/Router is not charging its battery to 100 percent?
Blanca
Community Team
Deek56
Mar 27, 2022Aspirant
Hi All
It turns out it was the Netgear charger plug that must have developed a fault, when I tried it with a different charger of the same specification (my phone charging plug) the MR1100-100 charged up fully.
Problem solved.
